Installed Ubuntu first time on my pc. Flashed it on my flash-drive, ran it on my computer and decided to install, after successful installation computer restarts and I only see white line on black blank screen. Again boot from flash drive, run installation and face the same problem.
Computer specifications:
CPU: Intel Core i5-2310 2.90GHz
Motherboard: MSI MS-7732
RAM: DDR3, 4096 МБ (2х 2048 МБ)
HDD: SAMSUNG HD161HJ (149 ГБ)
GPU: NVIDIA GeForce GTS 450
david6
  • 14,528
  • 38
  • 46
dima23
  • 13
I'm guessing your boot loader's installation failed. Boot on your Live drive, and try to reinstall it. In order to do so, select Try Ubuntu when prompted, wait for the environment to load, and open a terminal by doing Ctrl + Alt + T. Become root by typing sudo -i an proceed with the following commands :
grub-install --recheck /dev/sda # Install GRUB on sda (adapt this line, see below)
update-grub # Generate configuration.
Note : you can find your hard drive's device file (/dev/sdX) by doing :
fdisk -l # As root, again.
You'll recognise your partitions, and hard drives. On most computers, there is only one hard drive, and the kernel loads it on /dev/sda.
Reboot, and everything should be fine.
