I've spent most of today installing Server 11.04. While I can't get network installs to work at all (different issue, I'll post a separate question/bug), when installing from the server CD, all goes well until I reboot. When the computer reboots, I'm presented with a blank screen. I can't switch to other virtual terminals, but the system is running.
By accident I found that if I boot with the monitor unplugged, and plug it in after the computer is booted, the login prompt displays just fine. This is a server, so there is no Xorg involved, but it seems as though it tries to display some unsupported text mode.
I've replicated it on two servers. One is a Dell and one is an HP. They both have onboard video, no secondary video card.
Any idea where to change that?
Jorge Castro
  • 73,717
I suggest you turn off he onboard intel graphics and just allow the secondary graphics.You can do this in the BIOS
Amith KK
  • 13,547
I was having a similar problem, without a monitor, it was not booting.
do a :
sudo nano /etc/default/grub
and take a look at this setting:
GRUB_HIDDEN_TIMEOUT
Is it commented out like so? If so uncomment it (remove the #):
#GRUB_HIDDEN_TIMEOUT=0
According to this post: http://ubuntuforums.org/showthread.php?t=1195275 The GRUB_HIDDEN_TIMEOUT_QUIET is not working right, and i can attest to that. So as a workaround i put the uncommented the GRUB_HIDDEN_TIMEOUT=0 and it now goes boots without a monitor.
GRUB_HIDDEN_TIMEOUT_QUIET=true Used with the GRUB_HIDDEN_TIMEOUT setting. true - No countdown is displayed. The screen will be blank. false - A counter will display on a blank screen for the duration of the GRUB_HIDDEN_TIMEOUT value. This feature currently appears to be broken; the timeout counter isn't appearing when set to 'false' or not set.
Jorge Castro
  • 73,717
capdragon
  • 1,047
A system update fixed this for me. In fact, even a new install (which installs updates) works fine now.
