I am having problems with my wireless connection using ath9k, I cannot connect to any wireless network. I can connect to the wireless network fine on windows 8.1 but when using ubuntu gnome I have no luck.
Any Help Appreciated.
OS: Ubuntu Gnome 13.10
What has been tried so far:
sudo modprobe -r ath9k
sudo modprobe ath9k nohwcrypt=1
sudo modprobe -r brcmsmac
echo "blacklist brcmsmac" | sudo tee -a /etc/modprobe.d/blacklist.conf
Wireless Card: TP Link TL-WDN3800
*************** info trace ***************
***** uname -a *****
Linux jamie 3.11.0-12-generic #19-Ubuntu SMP Wed Oct 9 16:20:46 UTC 2013 x86_64     x86_64 x86_64 GNU/Linux
***** lsb_release *****
Distributor ID: Ubuntu
Description:    Ubuntu 13.10
Release:    13.10
Codename:   saucy
***** lspci *****
03:00.0 Network controller [0280]: Qualcomm Atheros AR93xx Wireless Network Adapter     [168c:0030] (rev 01)
Subsystem: Qualcomm Atheros Device [168c:3116]
Kernel driver in use: ath9k
04:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd.     RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 06)
Subsystem: Gigabyte Technology Co., Ltd Motherboard [1458:e000]
Kernel driver in use: r8169
***** lsusb *****
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 009 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 004 Device 004: ID 15d9:0a4d Trust International B.V. Optical Mouse
Bus 004 Device 007: ID 413c:2107 Dell Computer Corp.
Bus 004 Device 002: ID 2109:3431
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
***** PCMCIA Card Info *****
***** iwconfig *****
wlan0     IEEE 802.11abgn  ESSID:off/any
      Mode:Managed  Access Point: Not-Associated   Tx-Power=20 dBm
      Retry  long limit:7   RTS thr:off   Fragment thr:off
      Power Management:off
***** rfkill *****
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
***** lsmod *****
brcmsmac              562767  0
cordic                 12574  1 brcmsmac
brcmutil               15618  1 brcmsmac
bcma                   46670  1 brcmsmac
ath9k                 151173  0
ath9k_common           13859  1 ath9k
ath9k_hw              444645  2 ath9k_common,ath9k
ath                    23827  3 ath9k_common,ath9k,ath9k_hw
mac80211              596969  2 ath9k,brcmsmac
cfg80211              479757  4 ath,ath9k,brcmsmac,mac80211
***** nm-tool *****
NetworkManager Tool
State: disconnected
- Device: eth0 -----------------------------------------------------------------
  Type:              Wired
  Driver:            r8169
  State:             unavailable
  Default:           no
  HW Address:        94:DE:80:78:51:14
  Capabilities:
    Carrier Detect:  yes
  Wired Properties
    Carrier:         off
- Device: wlan0 ----------------------------------------------------------------
  Type:              802.11 WiFi
  Driver:            ath9k
  State:             disconnected
  Default:           no
  HW Address:        A0:F3:C1:24:C5:87
  Capabilities:
  Wireless Properties
    WEP Encryption:  yes
    WPA Encryption:  yes
    WPA2 Encryption: yes
  Wireless Access Points
    BTWiFi-with-FON: Infra, 02:22:69:6B:FF:48, Freq 2437 MHz, Rate 54 Mb/s, Strength 57
    BTWiFi:          Infra, 02:22:69:6B:FF:4B, Freq 2437 MHz, Rate 54 Mb/s, Strength 65
    TalkTalk:        Infra, 20:F3:A3:FE:0D:16, Freq 2462 MHz, Rate 54 Mb/s, Strength 82 WPA WPA2
    BTHomeHub2-TMW4: Infra, 00:22:69:6B:FF:4A, Freq 2437 MHz, Rate 54 Mb/s, Strength 64 WPA WPA2
    virginmedia2978209: Infra, 74:44:01:F3:23:C0, Freq 2462 MHz, Rate 54 Mb/s, Strength 30 WPA WPA2
***** NetworkManager.state *****
[main]
NetworkingEnabled=true
WirelessEnabled=true
WWANEnabled=true
WimaxEnabled=true
***** NetworkManager.conf *****
[main]
plugins=ifupdown,keyfile,ofono
dns=dnsmasq
[ifupdown]
managed=false
***** interfaces *****
# interfaces(5) file used by ifup(8) and ifdown(8)
auto lo
iface lo inet loopback
***** iwlist *****
wlan0     Scan completed :
      Cell 01 - Address: 20:F3:A3:FE:0D:16
                Channel:11
                Frequency:2.462 GHz (Channel 11)
                Quality=64/70  Signal level=-46 dBm
                Encryption key:on
                ESSID:"TalkTalk"
                Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 6 Mb/s
                          9 Mb/s; 12 Mb/s; 18 Mb/s
                Bit Rates:24 Mb/s; 36 Mb/s; 48 Mb/s; 54 Mb/s
                Mode:Master
                Extra:tsf=000000009e93517f
                Extra: Last beacon: 1156ms ago
                IE: Unknown: 000854616C6B54616C6B
                IE: Unknown: 010882848B960C121824
                IE: Unknown: 03010B
                IE: Unknown: 050400010000
                IE: Unknown: 2A0104
                IE: Unknown: 32043048606C
                IE: Unknown:     2D1A0E181EFF00000000000000000000000000000000000000000000
                IE: Unknown: 3D160B070000000000000000000000000000000000000000
                IE: WPA Version 1
                    Group Cipher : TKIP
                    Pairwise Ciphers (2) : TKIP CCMP
                    Authentication Suites (1) : PSK
                IE: IEEE 802.11i/WPA2 Version 1
                    Group Cipher : TKIP
                IE: Unknown: DD180050F2020101000003A4000027A4000042435E0062322F00
                IE: Unknown: DD1E00904C330E181EFF00000000000000000000000000000000000000000000
                IE: Unknown: DD1A00904C340B070000000000000000000000000000000000000000
                IE: Unknown: DD0600E04C020160
                IE: Unknown: DD0E0050F204104A0001101044000102
      Cell 02 - Address: 74:44:01:F3:23:C0
                Channel:11
                Quality=24/70  Signal level=-86 dBm
                Encryption key:on
                ESSID:"virginmedia2978209"
                Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 18 Mb/s
                          24 Mb/s; 36 Mb/s; 54 Mb/s
                Bit Rates:6 Mb/s; 9 Mb/s; 12 Mb/s; 48 Mb/s
                Mode:Master
                Extra:tsf=0000011cc720019c
                Extra: Last beacon: 1172ms ago
                IE: Unknown: 001276697267696E6D6564696132393738323039
                IE: Unknown: 010882848B962430486C
                IE: Unknown: 03010B
                IE: Unknown: 2A0100
                IE: Unknown: 2F0100
                    Group Cipher : TKIP
                    Pairwise Ciphers (2) : CCMP TKIP
                IE: Unknown: 32040C121860
                IE: Unknown: 2D1AFC181BFFFF000000000000000000000000000000000000000000
                IE: Unknown: 3D160B080400000000000000000000000000000000000000
                IE: Unknown: DD180050F204104A00011010440001021049000600372A000120
                IE: Unknown: DD090010180203F02C0000
                IE: WPA Version 1
                    Group Cipher : TKIP
                IE: Unknown: DD180050F2020101800003A4000027A4000042435E0062322F00
***** resolv.conf *****
***** blacklist *****
Output for lsmod | grep -E 'ath|brcmsmac'
** lsmod | grep -E 'ath|brcmsmac' **
ath9k                 151173  0
mac80211              596969  1 ath9k
cfg80211              479757  3 ath,ath9k,mac80211
Output for dmesg | grep -E 'cfg|ath|wlan'
Jamie
  • 41
Execute:
Then try to connect. That should work.
If it does (or even if it doesn't) work, execute the following:
Then reboot.
Alaa Ali
  • 32,213
Try using
rfkill list all
in the terminal. It will bring up something that looks like this
`0: phy0: Wireless LAN Soft blocked: yes Hard blocked: no 1: hp-wifi: Wireless LAN Soft blocked: no Hard blocked: no
If any of them come back saying yes userfkill unblock all Hopefully this fixes the issue
Jbuch14
  • 1,137
