Recently I got stuck with Unity since it does not work at all - I see no system bar nor Unity launcher (3D/2D). Possible causes are: system update/upgrade or playing with drivers (additional fglrx or downloaded from AMD website). I would point on recent system update since I saw there OpenGL-something.
EDIT
How have I reanimated Unity:
FIRST reading askubuntu and Google answers
- reinstalled Unity,
- changed drivers,
THEN reading unity --reset
- fixed broken links to libGL.so and added few more,
THEN reading answers
- enabled Unity in ccsm
- added libatiuki.so links to /lib32 and /lib (was only in /lib64).
Now it kind of works, but unity --reset (below) tells another story.
I'd be glad to know how to fix those errors:
WARNING: Unity currently default profile, so switching to metacity while resetting the values
Checking if settings need to be migrated ...no
Checking if internal files need to be migrated ...no
Backend : gconf
Integration : true
Profile : unity
Adding plugins
Initializing core options...done
compiz (core) - Warn: failed to receive ConfigureNotify event on 0x2400004
compiz (core) - Warn: failed to receive ConfigureNotify event on 0x1400002
compiz (core) - Warn: failed to receive ConfigureNotify event on 0x1600002
compiz (core) - Warn: failed to receive ConfigureNotify event on 0x40000dd
Initializing composite options...done
Initializing opengl options...done
Initializing decor options...done
Initializing vpswitch options...done
Initializing snap options...done
Initializing mousepoll options...done
Initializing resize options...done
Initializing place options...done
Initializing move options...done
Initializing wall options...done
Initializing grid options...done
Initializing session options...done
Initializing gnomecompat options...done
Initializing animation options...done
Initializing fade options...done
Initializing unitymtgrabhandles options...done
Initializing workarounds options...done
Initializing scale options...done
compiz (expo) - Warn: failed to bind image to texture
Initializing expo options...done
Initializing ezoom options...done
(compiz:5391): GConf-CRITICAL **: gconf_client_add_dir: assertion `gconf_valid_key (dirname, NULL)' failed
error subscribing to gestures
WARN 2014-01-04 16:14:47 unity.favorites FavoriteStoreGSettings.cpp:139 Unable to load GDesktopAppInfo for 'ubiquity-gtkui.desktop'
compiz (unityshell) - Error: GL_ARB_vertex_buffer_object not supported
X Error of failed request: BadAccess (attempt to access private resource denied)
Major opcode of failed request: 33 (X_GrabKey)
Serial number of failed request: 6214
Current serial number in output stream: 6460
