The issue here is that unzip *.zip doesn't work for some reason. I guess the unzip doesn't accept wildcard path arguments for files.
Nux's answer is good but I use a slightly different version of the find command. If you cd into the folder you've downloaded all the zip files then you can just run:
find . -type f -name "*.zip" -exec unzip {} \;
This will search the current working directory and all sub-directories recursively with ., then find only files, -type f, then search for anything named *.zip with-nameand it will execute unzipexec unzipand substitute the result of the search which is the full file name and place it with{}after the unzip command as the argument.\;` is just magical syntax to say 'I'm done the command is finished.'.
This still worked for me in Ubuntu 16.04 to unzip all files in the current directory after downloading a huge number.
A similar command can also used to unrar a set of rar files you've downloaded simultaneously as well:
find . -type f -name "*.rar" -exec unrar x -e {} \;
The above magical command will search all files in the current directory and all folders and files recursively in sub-directories to find all files that end in .rar and then unrar them directly to the current working directory.
Let's say you want to unpack a bunch of stuff that you've just recently downloaded:
Fri Nov 17 10:56 AM Downloads: tree .
├── download1
│ ├── show01.r00
│ ├── show01.r01
│ ├── show01.r02
│ └── show01.rar
├── download2
│ ├── movie01.r00
│ ├── movie01.r01
│ ├── movie01.r02
│ ├── movie01.r03
│ └── movie01.rar
└── download3
├── program01.r00
├── program01.r01
├── program01.r02
├── program01.r03
└── program01.rar
3 directories, 14 files
This is only a small example you could have 20 or even 40 different foldedrs each containing their own master .zip file or .rar file that needs to be unrar'd. Doing a CD into each individual download directory to use 'unrar' is both time consuming and wasteful. Just use the find command!
sudo apt-get install unzip
sudo apt-get install unrar
cd ~/Downloads
