31
I'm trying to install bitcoind by simply doing sudo apt-get install bitcoind, but I get this error saying that the following packages could not be authenticated:
libdb5.1++ libcrypto++9 bitcoind
I can simply install them without authenticating them, but since this program may handle money, I would like them to be the correct ones. So I found this solution here on AskUbuntu, which suggests to do the following:
$ sudo apt-key update
$ sudo apt-get update
After the first command, it lists four keys of which it says that all remain unchanged. The second command simply does the usual, but it ends with a message saying that there was a GPG-error. After some blabla, it then says that the following signatures are invalid (freely translated from Dutch):
BADSIG 16126D3A3E5C1192 Ubuntu Extras Archive Automatic Signing Key <ftpmaster@ubuntu.com>
BADSIG 40976EAF437D05B5 Ubuntu Archive Automatic Signing Key <ftpmaster@ubuntu.com>
And the following signatures could not be verified because the public key is not available:
NO_PUBKEY 1F968B3903D886E7
And the following sugnatures were invalid:
BADSIG E585066A30C18A2B Opera Software Archive Automatic Signing Key 2013 <packager@opera.com>
And that getting stuff from the following address has failed:
 http://extras.ubuntu.com/ubuntu/dists/precise/Release
Does anybody know what I can do to solve this?
kramer65
  • 2,193
You have to add the pub key manually.
The command is
sudo apt-key adv --recv-key --keyserver keyserver.ubuntu.com «key number»
where «key number» you must replace it with the missing key.
For example in this error you received
you can do
sudo apt-key adv --recv-key --keyserver keyserver.ubuntu.com 1F968B3903D886E7
sudo apt-get update
That way you will download this key in your keyring from the keyserver (keyserver.ubuntu.com)
About the BADSIG error, check this answer here
NickTux
  • 17,865
  • 57
  • 66
Not the direct answer maybe, but there is a need to update the program: update-manager-core . If any users are getting the error that packages cannot be authenticated when running update manager, then updating this program also updates update managerand provides a really quick answer.
BTW, I used synaptic to do this update, if that is any help. Once the update processed, then update manager worked as it normally does.
see 1204_HWE_EOL in Ubuntu wiki
Ricgal
