I want to set a limit on how much each account can store, on Ubuntu 13.10. Is there a way to do this?
For example, I want to make it so each person can only store 40 GBs on their account
Disk quotas must be established, and this YoLinux page illustrates the procedure, and this AskUbuntu page will also illustrate the concept.
A brief overview follows:
00) Decide if you want to assign storage limits individually or set by group.
0) If by group, create the group and assign users to it.
1) Edit file /etc/fstab to add qualifier "usrquota" or "grpquota" to the partition
2) Set the name for the quota, with
touch /partition/aquota.user
where the partition might be /home or some partition defined in /etc/fstab , then do (root should be the owner of the quota file) chmod 600 /partition/aquota.user
3) Re-mount the file partition with quotas, or reboot.
4) quotacheck -vgum /partition to scan a file system for disk usages, and update the quota record file "quota.user/aquota.user" to the most recent status. It's good to make sure this runs every reboot as well as weekly-to-quarterly with cron.
5) quotaon -av (and I'd watch for the result at reboot time)
6) 'edquota -u user_id' - and if you get zeros, something's broken (use 'edquota -g group_name' for groups, instead)
7) quota -u user_id will list the quota for that user, quota -q shows users over the quota limit and you can get a quota summary report with repquota -a
K7AAY
  • 17,705
