I am trying to use the fstrim command on my machine. The configuration is as follows :
ubuntu@ip-172-16-10-56:~/test$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 12.10
Release:    12.10
Codename:   quantal
And I have created the fstrim in the /etc/cron.daily using the following commands:
sudo root vi /etc/cron.daily/fstrim
And fstrim file contains :
#! /bin/sh
# By default we assume only / is on an SSD.
# You can add more SSD mount points, separated by spaces.
# Make sure all mount points are within the quotes. For example:
# SSD_MOUNT_POINTS='/ /boot /home /media/my_other_ssd'
SSD_MOUNT_POINTS='/mnt'
for mount_point in $SSD_MOUNT_POINTS
do
    fstrim $mount_point
done
and then saved it and tried to run it using the command:
ubuntu@ip-172-16-10-56:/etc/cron.daily$ sudo /etc/cron.daily/fstrim
fstrim: /mnt: FITRIM ioctl failed: Operation not supported
I get that error everytime. I am not sure what is it that I am doing wrong.
I am following the instructions mentioned in How to enable TRIM?
Any help will be greatly appreciated.
Thanks Anjali
You appear to be trying to trim /mnt is something mounted as /mnt ? usually people use /mnt/myPartationName most likely defined in /etc/fstab
If you are only using a single partition and you are running on a SSD change this:
to this:
SSD_MOUNT_POINTS='/'
If that is the case you could just put fstrim / as your cron job instead of that entire script like this
#!/bin/sh
fstrim /
Here is a SSD guide: https://sites.google.com/site/easylinuxtipsproject/ssd
You are likely trying to TRIM a file system which doesn't have TRIM support under linux. You can't do anything with that. What type of filesystem are you trying to TRIM?
falconer
  • 15,334
