I'am using Ubuntu 13.04 on Lenovo G500 -E
when i turn my laptop computer on the brightness of screen is 0 and i need to increase the brightness to see the screen
is this problem related to Ubuntu 13.04?
please help me to solve this problem
thanks in advance,
You can try to login and set the brightness via the brightness control.
Or you can try if it works with this terminal command
echo 1666 >> /sys/class/backlight/intel_backlight/brightness
if this works you can add this command to the /etc/rc.local file which will run this command at startup process.
ps. you can change 1666 to whatever you want (more or less brightness)
klar
  • 16
