I want to encrypt my files and folders without full disk encryption and encrypted volumes. Can anyone help me?
Asked
Active
Viewed 169 times
This site should give you all the information you need. The link was found at upubuntu.com. Here is a direct quote from the site:
"encrypt or decrypt your files using the Nautilus context menu (right-click menu) under Ubuntu"
- Add a PGP key so that you can encrypt your files with it, by opening "Passwords and Keys", click the add button, select "PGP Key", then click Continue.
- Add the seahorse-nautilus plugin with
sudo apt-get install seahorse-nautilus && nautilus -q && nautilus
- Right click to pick any file and then select Encrypt In a pop-up, pick your key, set "Sign message as: Your key" and click OK. Another pop-up asks for the passphrase which matches up w/ the PGP key.
Amanda
- 9,723
spinster3908
- 691
