57
Each time apt-get tries to process triggers for shared-mime-info, it reports warnings like:
Processing triggers for shared-mime-info...
Unknown media type in type 'all/all'
Unknown media type in type 'all/allfiles'
Unknown media type in type 'uri/mms'
Unknown media type in type 'uri/mmst'
Unknown media type in type 'uri/mmsu'
Unknown media type in type 'uri/pnm'
Unknown media type in type 'uri/rtspt'
Unknown media type in type 'uri/rtspu'
Unknown media type in type 'interface/x-winamp-skin'
I've checked /usr/share/mime-info but doesn't see any of them:
/usr/share/mime-info$ grep 'url/rtspu' *
(Got nothing)
So, how to clean up my system so it won't report these unknown media types?
Tim
  • 33,500
Lenik
  • 10,608
Backup the file that is causing the errors and update the systems mime database:
sudo mv -vi /usr/share/mime/packages/kde.xml /usr/share/mime/packages/kde.xml.bak
sudo update-mime-database /usr/share/mime
This should fix the warnings.
hakre
  • 209
17
This was discussed in Why does update-mime-database complain about uri/rtspt and other unusual types? It is caused by kde.xml and they have not fixed it yet. Here is a bug report.
Also it's uri/rtspu, not url/rtspu you should be grepping.
skfd
  • 500
10
You should check /usr/share/mime/packages for the specific xml that contains the phrase you get .
For example, my problem was Unknown media type in type 'chemical/...... I found the file /usr/share/mime/packages/chemical-mime-data.xml.
Using cat on the file showed me that the package was the same chemical-mime-data V 0.94
So I ran:
sudo apt-get remove chemical-mime-data
Tim
  • 33,500
