I tried to install an app written in Python using this command in terminal:
sudo make install
at the very last stage of installation, this message pops up:
[ -x /usr/bin/update-desktop-database ] && sudo update-desktop-database -q
I just want to know what it means and how to finish installation process.
kiri
  • 28,986
The line
means "if /usr/bin/update-desktop-database exists and is executable then run sudo update-desktop-database -q.
The command update-desktop-database creates a database of MIME type handlers from the information found in the .desktop files in /usr/share/applications, /usr/local/share/applications and $HOME/.local/share/applications.
Most likely the installation process is finished now and you should be able to use the app.
