My answer is based on Mik's** very thorough response here: What is dconf, what is its function, and how do I use it?.
I'm assuming that your Xubuntu is a default one and that you are using Network Manager with nm-applet.
To reverse the action of clicking "Never show this notification again", open your terminal and paste in the following:
gsettings get org.gnome.nm-applet disable-vpn-notifications
The status will be returned to you. In my case, the response is "false".
In your case, to revert to seeing the notifications again, now paste in the following:
gsettings set org.gnome.nm-applet disable-vpn-notifications false
Alternatively, you could just reset the value to the default by using:
gsettings reset org.gnome.nm-applet disable-vpn-notifications
You may need to disable networking and renable it or log off and log in again or reboot for the changes to take effect.
Edit: there is a GUI if you want to avoid using the terminal. It's called dconf editor and you can get it from the software center or by running:
sudo apt-get install dconf-tools
Again, Mik's answer describes its usage but, at least in the past, there have been instances of confusion: an example is here: Are dconf schema names case-sensitive?.
**Mik has asked for his account to be deleted according to this.
