I'm trying to install TeamViewer 9 from deb file however it says it needs ia32-libs so it won't install:
I tried to do some fix with sudo apt-get dist-upgrade but:
$ sudo apt-get install ia32-libs-multiarch
Reading package lists... Done
Building dependency tree
 ia32-libs-multiarch:i386 : Depends: libglapi-mesa:i386
                            Depends: libglu1-mesa:i386 but it is not going to be installed
                            Depends: libqt4-opengl:i386 but it is not going to be installed
                            Recommends: libgl1-mesa-glx:i386
                            Recommends: libgl1-mesa-dri:i386
What is the work-around for this?
I have run into this issue before with other programs that have 32-bit dependencies.
To fix on Ubuntu, the following worked for me (through terminal):
sudo apt-get update
sudo apt-get install lib32gcc1
For Debian, you need to specify the architecture:
sudo dpkg --add-architecture i386
sudo apt-get update
Ross
  • 1,150
One of the way that unmet dependencies results is, when the installing package depend on other package which has its own dependent packages.
System installs only the installing package's dependencies. If those dependencies has their own dependencies (second level), then error of unmet dependencies results.
Here libglu1-mesa, libqt4-opengl also depends on other packages.
In such a case. it should be include the packages those not going to be installed to the installation list.
For extra safety, it is better to run --install-recommends to install the recommended packages even.
So run :
sudo apt-get --install-recommends install ia32-libs-multiarch libglu1-mesa libqt4-opengl
