This seems to be a bug, but i'm not sure which package to report it on. Try this:
  • Open gnome-terminal
  • shift-ctrl-t (open a new tab)
  • type: foo foo &
  • The tab is closed
Correct behavior would be Command not found.
This happens every time on gnome-terminal. On xterm (without tabs of course) it works randomly - maybe 2 of 3 times tried.
Avinash Raj
  • 80,446
cos
  • 31
Let me guess, there is set -e (or it’s long form set -o errexit) option in your .bashrc (.bash_profile).
-e
Exit immediately if a pipeline (which may consist of a single simple command), a subshell command enclosed in parentheses, or one of the commands executed as part of a command list enclosed by braces (see SHELL GRAMMAR above) exits with a non-zero status. The shell does not exit if the command that fails is part of the command list immediately following a while or until keyword, part of the test following the if or elif reserved words, part of any command executed in a && or || list except the command following the final && or ||, any command in a pipeline but the last, or if the command’s return value is being inverted with !. A trap on ERR, if set, is executed before the shell exits. This option applies to the shell environment and each subshell environment separately (see COMMAND EXECUTION ENVIRONMENT above), and may cause subshells to exit before executing all the commands in the subshell.
— bash(1)
This option is very useful for some scripts – it allows to avoid numerous || exit 1, e. g. instead of
cd /var/ || exit 1
tar -cvf myarchive.tar "$SOMEDIR" || exit 1
rm -r "$SOMEDIR"
you can write
set -e
cd /var/
rm -r "$SOMEDIR"
But of course there is no any reason to set it for interactive bash session.
Dmitry Alexandrov
  • 1,668
  • 13
Check and verify that you don't have some bashrc or profile configuration to change the normal behaviour of this instance.
The best way to verify this is to backup your current bashrc and profile files then replace the active ones with virgin copies of those two files. Log out then log back in and check if you still have this behaviour.
If this cures this flaw, carefully add your custom configuration, and take note to the last change made if the flaw comes back.
Bruno Pereira
  • 74,715
L. D. James
  • 25,444
