I'm trying to get cgminer 3.5 on my Ubuntu 12.04 to work but it fails because libudev.so.1 is missing. I tried to install libc6 and now I have unmet dependencies. Even when I try to run sudo apt-get -f install I get this error:
Reading package lists... Done
Building dependency tree
Correcting dependencies... failed.
libc6-dev : Depends: libc6 (= 2.17-0ubuntu5.1) but 2.15-0ubuntu10.5 is installed
Depends: libc-dev-bin (= 2.17-0ubuntu5.1)
libudev1 : Depends: libc6 (>= 2.17) but 2.15-0ubuntu10.5 is installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
E: Unable to correct dependencies
I already tried to add the raring security repo (eb http://security.ubuntu.com/ubuntu raring-security main) in my sources.list file, run apt-get update etc. but it still want'S to reinstall the 2.15 version which causes errors.
\Edit:
apt-cache policy libc6-dev libc6 libc-dev-bin libudev1
libc6-dev:
Installed: 2.17-0ubuntu5.1
Candidate: 2.17-0ubuntu5.1
Version table:
*** 2.17-0ubuntu5.1 0
500 http://security.ubuntu.com/ubuntu/ raring-security/main amd64 Packages
100 /var/lib/dpkg/status
2.15-0ubuntu10.5 0
500 http://us.archive.ubuntu.com/ubuntu/ precise-updates/main amd64 Packages
500 http://security.ubuntu.com/ubuntu/ precise-security/main amd64 Packages
2.15-0ubuntu10 0
500 http://us.archive.ubuntu.com/ubuntu/ precise/main amd64 Packages
libc6:
Installed: 2.15-0ubuntu10.5
Version table:
2.17-0ubuntu5.1 0
*** 2.15-0ubuntu10.5 0
2.15-0ubuntu10 0
libc-dev-bin:
Version table:
2.17-0ubuntu5.1 0
2.15-0ubuntu10 0
libudev1:
Installed: 198-0ubuntu11
Candidate: 198-0ubuntu11.2
Version table:
198-0ubuntu11.2 0
*** 198-0ubuntu11 0
And the output of apt-get check:
apt-get check
You might want to run 'apt-get -f install' to correct these.
E: Unmet dependencies. Try using -f.
apt-get -u dist-upgrade has the same problem. Any idea how I can resolve that?
/Edit 2
apt-get -f install libc6-dev=2.17-0ubuntu5.1 libc6=2.17-0ubuntu5.1 libc-dev-bin=2.17-0ubuntu5.1 libudev1=198-0ubuntu11.2Reading package lists... Done
libc6 is already the newest version.
libc6-dev is already the newest version.
libc6-dev set to manually installed.
You might want to run 'apt-get -f install' to correct these:
libc6 : Breaks: libc6:i386 (!= 2.17-0ubuntu5.1) but 2.15-0ubuntu10.5 is to be installed
libc6:i386 : Breaks: libc6 (!= 2.15-0ubuntu10.5) but 2.17-0ubuntu5.1 is to be installed
libnih1 : PreDepends: libc6 (< 2.16) but 2.17-0ubuntu5.1 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
\Edit 3
apt-cache policy libnih1 libc6 libc6:i386libnih1:
Installed: 1.0.3-4ubuntu9.1
Candidate: 1.0.3-4ubuntu9.1
Version table:
*** 1.0.3-4ubuntu9.1 0
1.0.3-4ubuntu9 0
libc6:
Version table:
2.15-0ubuntu10.5 0
2.15-0ubuntu10 0
libc6:i386:
Version table:
2.17-0ubuntu5.1 0
500 http://security.ubuntu.com/ubuntu/ raring-security/main i386 Packages
500 http://us.archive.ubuntu.com/ubuntu/ precise-updates/main i386 Packages
500 http://security.ubuntu.com/ubuntu/ precise-security/main i386 Packages
2.15-0ubuntu10 0
500 http://us.archive.ubuntu.com/ubuntu/ precise/main i386 Packages
Edit 4
apt-get remove libnih1
libc-dev-bin : Depends: libc6 (< 2.16) but 2.17-0ubuntu5.1 is to be installed
libc6-dev : Depends: libc-dev-bin (= 2.17-0ubuntu5.1)
libnih-dbus1 : Depends: libnih1 (= 1.0.3-4ubuntu9.1) but it is not going to be installed
mountall : Depends: libnih1 (>= 1.0.0) but it is not going to be installed
upstart : Depends: libnih1 (>= 1.0.0) but it is not going to be installed
ureadahead : Depends: libnih1 (>= 1.0.0) but it is not going to be installed
Edit 5
Output of lsb_release:
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 12.04.3 LTS
Release: 12.04
Codename: precise
Output of apt-get install libc6=2.15-0ubuntu10.5 after removing raring repos and updating:
libc6-dev : Depends: libc6 (= 2.17-0ubuntu5.1) but 2.15-0ubuntu10.5 is to be installed
Edit 6
sudo apt-get install libc6-dev=2.15-0ubuntu10.5 libc6=2.15-0ubuntu10.5
The following packages were automatically installed and are no longer required:
gir1.2-ubuntuoneui-3.0 libubuntuoneui-3.0-1 thunderbird-globalmenu
Use 'apt-get autoremove' to remove them.
Suggested packages:
glibc-doc
The following packages will be DOWNGRADED:
libc6 libc6-dev
0 upgraded, 0 newly installed, 2 downgraded, 0 to remove and 18 not upgraded.
3 not fully installed or removed.
Need to get 7,596 kB of archives.
After this operation, 486 kB disk space will be freed.
Do you want to continue [Y/n]? Y
Get:1 http://us.archive.ubuntu.com/ubuntu/ precise-updates/main libc6-dev amd64 2.15-0ubuntu10.5 [2,941 kB]
Get:2 http://us.archive.ubuntu.com/ubuntu/ precise-updates/main libc6 amd64 2.15-0ubuntu10.5 [4,654 kB]
Fetched 7,596 kB in 6s (1,095 kB/s)
Preconfiguring packages ...
dpkg: warning: downgrading libc6 from 2.17-0ubuntu5.1 to 2.15-0ubuntu10.5.
(Reading database ... 240709 files and directories currently installed.)
Preparing to replace libc6 2.17-0ubuntu5.1 (using .../libc6_2.15-0ubuntu10.5_amd64.deb) ...
Unpacking replacement libc6 ...
dpkg: error processing /var/cache/apt/archives/libc6_2.15-0ubuntu10.5_amd64.deb (--unpack):
'./usr/share/lintian/overrides/libc6' is different from the same file on the system
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
