I want my computer automatically boot my Ubuntu system. But it always starts with this list:
Linux 3.2.0-57-generic-pae
Linux 3.2.0-57-generic-pae (recovery mode)
Linux Privous
Memory test (memtest86+)
I want my computer to automatically boot into Linux 3.2.0-57-generic-pae.
This is my /etc/default/grub file:
# If you change this file, run 'update-grub' afterwards to update
# /boot/grub/grub.cfg.
# For full documentation of the options in this file, see:
#   info -f grub -n 'Simple configuration'
GRUB_SAVEDEFAULT=true
GRUB_DEFAULT=saved
GRUB_HIDDEN_TIMEOUT=0
GRUB_HIDDEN_TIMEOUT_QUIET=true
GRUB_TIMEOUT=0
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash mem=4G video=LVDS-1:d"
GRUB_CMDLINE_LINUX=""
# Uncomment to enable BadRAM filtering, modify to suit your needs
# This works with Linux (no patch required) and with any kernel that obtains
# the memory map information from GRUB (GNU Mach, kernel of FreeBSD ...)
#GRUB_BADRAM="0x01234567,0xfefefefe,0x89abcdef,0xefefefef"
# Uncomment to disable graphical terminal (grub-pc only)
#GRUB_TERMINAL=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `vbeinfo'
#GRUB_GFXMODE=640x480
# Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
#GRUB_DISABLE_RECOVERY="true"
# Uncomment to get a beep at grub start
#GRUB_INIT_TUNE="480 440 1"
Flimm
  • 44,031
Jeffrey
Run this:
sudo nano /etc/default/grub
and set this line to saved, and remove any # from it as well:
GRUB_DEFAULT=saved
also, set this line to true:
If these lines are not in the file, add them in.
Edit: To get rid of GRUB completely, set this to 0:
GRUB_TIMEOUT=0
but as it is sometimes useful for GRUB to be shown, to recover the system, or boot to a different kernel, you may want to set this to 1 or 2 seconds:
GRUB_TIMEOUT=2
you could also hide the menu unless a key is pressed during the 2 seconds time period:
GRUB_TIMEOUT=0
GRUB_HIDDEN_TIMEOUT=2
Then save with Ctrl+O, and exit with Ctrl+X.
Then run:
sudo update-grub
which will update the configuration. Now, it should automatically select as default the entry you selected previously, and disappear after a timed delay, and hide if you wish it.
More on editing grub here
Wilf
  • 30,732
