I freshly installed Kubuntu 13.10, 32 bit version on newly purchased Dell Vostro 2420. everything is working fine except scrolling and multitouch features through touchpad. I am able to change position of cursor using touchpad and able to tap (single click and double click) but scrolling is not working
I tried to find out solution by searching on google but could not find proper solution to load synaptics drivers.
i am listing some details: Laptop: Dell Vostro 2420 Linux Kernel version and distribution: 3.11.0-12-generic, Kubuntu 13.10
output of xinput list is
⎡ Virtual core pointer                          id=2    [master pointer (3)]
⎜   ↳ Virtual core XTEST pointer                id=4    [slave  pointer  (2)]
⎜   ↳ PS/2 Generic Mouse                        id=12   [slave  pointer  (2)]
⎣ Virtual core keyboard                         id=3    [master keyboard (2)]
    ↳ Virtual core XTEST keyboard               id=5    [slave  keyboard (3)]
    ↳ Power Button                              id=6    [slave  keyboard (3)]
    ↳ Video Bus                                 id=7    [slave  keyboard (3)]
    ↳ Power Button                              id=8    [slave  keyboard (3)]
    ↳ Sleep Button                              id=9    [slave  keyboard (3)]
    ↳ Laptop_Integrated_Webcam_HD               id=10   [slave  keyboard (3)]
    ↳ AT Translated Set 2 keyboard              id=11   [slave  keyboard (3)]
    ↳ Dell WMI hotkeys                          id=13   [slave  keyboard (3)]
Output of synclient -l is
Couldn't find synaptics properties. No synaptics driver loaded?
output of lshw is at http://paste.ubuntu.com/6645687/
xserver log and dmesg dont have trace of synaptics
kindly tell me how to troubleshoot this problem.
Pilot6
  • 92,041
Alok
  • 504
I got the solution at http://www.dahetral.com/public-download
downloading and installing this solves my problem :)
Follow these steps and touchpad will be detected by the system
Download file from http://www.dahetral.com/public-download
Install
  1. extract psmouse-alps-1.3-alt.tbz to /
    For this you open Terminal
    run su
    Go to the downloaded file folder and execute the following
    run tar -xvf psmouse-alps-1.3-alt.tbz
    run mv usr/src/psmouse-alps-1.3 /usr/src
  2. run dkms add psmouse/alps-1.3
  3. run dkms install psmouse/alps-1.3
  4. reboot
Uninstall :
1. dkms remove psmouse/alps-1.3 --all
2. delete psmouse/alps-1.3
Alok
  • 504
Had the same problem with a fresh install of Kubuntu 14.04 on a Dell Inspiron 3521, but found a simpler solution. If the system settings tell you that the synaptics driver is not loaded (or not used) when you try to configure the touchpad, simply provide an xorg.conf for it. Turns out, there is a snippet already made for you. It is in /usr/share/X11/xorg.conf.d and it is named 50-synaptics.conf. In my case, there was no xorg.conf in /etc/X11, so I simply copied the snippet as xorg.conf into /etc/X11:
sudo cp -n /usr/share/X11/xorg.conf.d/50-synaptics.conf /etc/X11/xorg.conf
If an xorg.conf already exists, make sure it does not already contain the stanzas for the touchpad, and if it doesn't, append the 50-synaptics.conf snipped to the existing xorg.conf using your favorite editor (and sudo). If it has touchpad stuff in it, you have a different problem.
After re-starting X11 (re-boot would obviously work too), the touchpad worked like a charm.
user147058
  • 17
