I want to dualboot window 8 Pro and ubuntu.It can't boot ubuntu in first time,then i use easyBCD to change window boot Manager to boot ubuntu.I add Entries and Install NeoGrub.when I restart on Windows Boot Manager screen it has only "NeroGrub Bootloader" that I can choose.window 8 is disappeared ,then I use ubuntu "trying ubuntu mode" and use Boot-repair to repair grub.it 's work and return this : http://paste.ubuntu.com/6655010/ ,Now I can boot to my ubuntu,but window can't.on grub boot list I have
  • Ubuntu, with Linux 3.5.0-23-generic
  • Ubuntu, with Linux 3.5.0-23-generic(recover mode)
  • Windows UEFI bkpbootmgfw.efi
  • Window Boot UEFI loader
  • efi/EFI/Boot/bkpbootx64.efi
  • Window 8 (loader) (on /dev/sda4)
when I choose "Windows UEFI bkpbootmgfw.efi" or "Window Boot UEFI loader",it's go to Window Boot Manager screen and has only one choice "NeoGrub Bootloader".When i choose It's show error like
Window failed to start. A recent hardware or software change might be cause. To fix the problem: . . more details . file: \NST\NeoGrub.mbr status: 0xc000000f Info: The application or operating system couldn't be loaded ...
Help me please! I stuck with this problem for a week. Thankyou very much for all answer,Sorry for my weak skill grammar. Tell me if you want more information or don't understand my question.
DrNutsu
  • 123
You need to repair your windows bootloader and then make grub2 as default bootloader.To do that follow the below steps,
  • Boot windows installation disk then select the "windows repair" or "repair your computer" option before you go into the installation process.
  • After selecting windows repair option,it will take you to the next screen.In that screen select the "command prompt" option
  • Then run the below commands,on it.
    bootrec /fixmbr
    bootrec /fixboot
    bootrec /rebuildbcd
  • This will repair your windows bootloader.
  • Atlast ran boot-repair-disk and click on the recommended repair option.Now it works.
Avinash Raj
  • 80,446
