I installed Ubuntu and can't connect to the WIFI. The Wired connection is working and everything else is fine.
Asked
Active
Viewed 108 times
Here's how to connect to the wifi: Go to System Settings, and go to the Network tab. Select "Wireless Connection" from the left panel. Then, from the drop-down, select the network you want to connect to. It should prompt for a password (if there is one). Enter the password, and it should pop up a little notification saying something like "connected to network 54mbps" or something like that. If you don't get the notification, then there must be a problem either with your wifi card in your computer, or with your router. I would recommend restarting your router, and trying to connect again. If that doesn't work, then restart your computer. If none of that works, then it gets very complicated from there.
Hope this helps! --Michael
masulzen
- 55
