I want to make a shell script to run VI with sudo if I try to edit a file that I don't have write permissions and for that I created an alias
    alias vi=my_script.sh
    #!/bin/bash
    file=$1
    if [ -r $file ]
    then
       /usr/bin/vi $file
    else
       sudo /usr/bin/vi $file
    fi
However, no matter what, when try to edit, let's say /etc/hosts, I still not being allowed to edit it.
What am I doing wrong?
Ok assuming the bit in grey is your my_script.sh there are a few issues. First, the alias needs to be set in your .bashrc not in the file. More detail is here.
Now onto the script the -r test checks if the file is readable not if it is editable. You probably have read but not write permissions. So you should try
#! /bin/bash
if test -w $1
then
   /usr/bin/vi $1
else
   sudo /usr/bin/vi $1
fi
This should work. One tip I would add is that if you are having a problem with a bash script: Cover it in echo statements! One at the start to check it opens, one in each side of the the if statement to see where it goes.
I have modified your script to work
#!/bin/bash
file=$1
wown=$(/bin/ls -alF $file | awk '{print $3}')
if [ -r $file ] && [ $wown == $USER ]
then
    /usr/bin/vi $file
else
fi
And if you wish to access it directly from anywhere, you can put it in PATH (like ~/bin/) rather than making an alias for it.
sourav c.
  • 46,120
