10
So I'm trying to safely remove this USB drive, because when I don't it does not work properly. When I go on Nautilus and try to eject it, I get this error message:
Error ejecting: eject exited with exit code 1: eject: unable to eject, last error: Invalid argument
And when I try to safely remove it via Nautilus or Disk Utility:
Error detaching: helper exited with exit code 1: Detaching device /dev/sdb
USB device: /sys/devices/pci0000:00/0000:00:12.0/usb3/3-1)
SYNCHRONIZE CACHE: FAILED: No such file or directory
(Continuing despite SYNCHRONIZE CACHE failure.)
STOP UNIT: FAILED: No such file or directory
Doing a file system check on Disk Utility returns File system is clean.. Trying to unmount it via terminal returns this:
~sudo eject /dev/sdb
I've tried to unmount it on Windows (dual boot system), but I simply got an error message saying that it was unable to eject it. No programs running or anything.
Gus
  • 333
So, the problem has been solved thanks to Douggro, who helped me in the comments. I'm just reposting his answer here to close the question.
Try ls /media and see if the drive shows there. If it does, sudo umount /media/drivename – douggro
Gus
  • 333
To safely remove an unmounted drive, eject with sudo
sudo eject /dev/sdb
