Possible Duplicate:
Can I edit which icons appear in the Unity dash?
I'd like to change the default application that is associated 'view photos' on the dash. I can do the web and email ones via 'preferred applications', but not the photos one.
Is there a way to do this?
Setting an arbitrary photo app for the Dash shortcut is not possible in Ubuntu 11.04 but I think it will be possible in 11.10 which will be released in October.
In 11.04, Ubuntu uses the following list in order to fill in the View Photos shortcut.
  • Shotwell
  • F-Spot
  • gthumb
  • gwenview
  • eog
It will pick the first installed application from this list so if you want F-Spot instead just uninstall Shotwell (and of course, make sure F-Spot is installed). Unfortunately, there is no way to set the shortcut to an app not on this list (without recompiling the source code yourself which is not recommended).
Jeremy Bicha
  • 8,294
