I have a HP laptop with an nVidia card, and I'm using Ubuntu 11.04 (stable). I have set up TwinView using the nVidia X Server Settings application. If I boot up without my secondary monitor plugged in, the desktop is stretched and out of resolution. Unity and the main panel work and look normal, but any applications I run are also stretched and the resolution is wrong, making them virtually unusable. When I boot with my secondary monitor plugged in (via HDMI) everything is working fine.
I've drilled this down to my xorg.conf file. If I delete the file and restart, the primary monitor works fine but I need to configure nVidia to use TwinView again. For a laptop where I'm constantly switching between single and multiple monitors, this gets annoying...
So basically my question is: can I set up Ubuntu in a way where the dual monitor settings are ignored when only 1 monitor is plugged in? This worked fine in 10.10 (btw I still have that xorg.conf file, and it causes the same issue).
Here is my current xorg.conf file:
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings:  version 270.29  (buildd@allspice)  Fri Feb 25 14:42:07 UTC 2011
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0" 0 0
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
    Option         "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/psaux"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    # HorizSync source: edid, VertRefresh source: edid
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "Seiko/Epson"
    HorizSync       30.0 - 75.0
    VertRefresh     60.0
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
    BoardName      "GeForce GT 230M"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    Option         "TwinView" "1"
    Option         "metamodes" "DFP-0: nvidia-auto-select +1920+0, DFP-1: nvidia-auto-select +0+0"
    SubSection     "Display"
        Depth       24
    EndSubSection
EndSection
Cas
  • 8,707
Michael
  • 31
If this is a hybrid graphics laptop, try to install bumblebee to have both the Intel and Nvidia cards working simultaneously, and use gnome-display-properties for multi-screen configurations, which is better than nvidia twinview these days: https://launchpad.net/~hybrid-graphics-linux
sudo apt-get install git
# type password
git clone http://github.com/MrMEEE/bumblebee.git
cd bumblebee/
sudo ./install.sh
optirun glxgears
# check the speed and compare to running:
glxgears
# If you have google-chrome installed, you can try it with/without optirun and report the FPS values on the mailing list:
optirun google-chrome http://webglsamples.googlecode.com/hg/aquarium/aquarium.html
719016
  • 6,467
My first suggestion is to not use the xorg.conf as it tends to cause more problems than it solves.
What I suggest instead is disper which can be run on startup and if the monitor is not detected it will not switch the resolution. If you have a more complicated setup you can create a script with different disper setups as I did in this answer - How to automatically switch monitors with my laptop dock
Cas
  • 8,707
I've tackled this one too. The current file that works for me is at the end.
The main settings that keeps things in spec are:
Option "TwinViewXineramaInfoOrder" "CRT-0"
Option "metamodes" "CRT: nvidia-auto-select, DFP: nvidia-auto-select"
Option "TwinViewOrientation" "RightOf"
This also allows me to use a range of different monitors (connected at boot time) without having to worry about their resolution.
EndSection
Section "Files"
EndSection
Section "Monitor"
    ModelName      "DELL SE198WFP"
    HorizSync       30.0 - 83.0
    VertRefresh     56.0 - 75.0
    Option         "DPMS"
EndSection
Section "Device"
    Driver         "nvidia"
    BoardName      "GeForce 8400M GS"
EndSection
Section "Screen"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
        Depth       24
    EndSubSection
EndSection
AgentK
  • 1,120
