What encryption is used in a default Ubuntu full hard drive encryption and is it possible to specify another?
Asked
Active
Viewed 94 times
Probably AES256 (as I could figure out from https://help.ubuntu.com/community/EncryptedHome)
nsane
- 486
Apparently it uses an XTS-AES (AES-cipher) with a hash algorithm sha1 (256bit key-size) by default, using Linux Unified Key Setup (LUKS). You should be able to change this manually somewhere in the Ubiquity scripts, when the command cryptsetup is used.
Type in man cryptsetup for more information.
nsane
- 486
MrVaykadji
- 5,965
