I was trying to make my laptop running Ubuntu 13.10 remember the brightness from the last time and set it automatically on start-up. I was thinking about using xbacklight to set the brightness. So, as a test run I added xbacklight -set 100 inside /etc/rc.local. But simply it doesn't work. Permission for my rc.local is:
-rwxr-xr-x 1 root root 338 Dec 22 00:08 rc.local
I also tried adding sleep 60 considering its a timing issue. But still no luck.
ashik992
  • 171
You can put the command into ~/.gnomerc, it will be executed on login (It will be executed on Unity as well).
rc.local is executed before X startup, so the command is executed but it has no effect.
konairius
  • 171
