In olden days of DOS, we had cd command to switch folders. The case does not seem same like DOS. Please help
If you have a dir named "apps", with templates, static as its contents.
cd apps
will enter you to apps folder.
cd apps/templates
will enter you to templates directory
cd ..
you will reach to the apps dir
cd
you will reach main directory
you use the cd command , it stands for change directory.
the file system in linux is arranged in a tree beginning at the root or / directory.
One catch to lookout for is that using the cd command is relative to where you are now in the file system , unless you start the path after the cd command with a /
3 handy commands for traversing the filesystem
  • cd path or cd /path/path to change directory
  • pwd to display current directory you are in (present working directory)
  • ls to list the content of you current directory.
Pieter
  • 158
