I am in need of some help. It has been 2 weeks since I bought my first ever windows laptop with the aim of replacing windows but I have been unsuccessful.
The hardware is as follows : Asus 15' F550D with A8 AMD processor and Radeon HD 8670M graphics The laptops runs EFI "bios"
I managed to switch off Fastboot and Secure boot in EFI
so far I managed to to boot from USB which I mounted the Ubuntu 13.10 on but I can not get pass the GRUB menu as no matter when I chose I end up facing a black screen with back light on and I can not get anywhere beyond that.
I have tried the following with no success:
  • alternative versions of ubuntu ( 13.04 , 12.10 and Kubuntu 13.10 {all 64 bit}) problem remains.
  • editing the boot options in grub and using "nomodeset"
what can I try next ? any other suggestions ?
please help Windows 8 is sucking life out of me !!!
In a perfect world I would be aiming to have a dual boot system but if it's easier to lose the big virus living in my system , Windows 8, then i'm more than happy to go with that . ...
Tim
  • 33,500
This may sound stupid, but I think I may have (had) similar problem with my new Windows 8 preinstalled Lenovo G710 laptop. Here it is simply that after booting Ubuntu or - for example - GParted Live CD, the screen brightness is automatically set to zero. On this particular laptop I use I can control brightness by F11/F12 (or Fn+F11/Fn+F12 depending on BIOS setup's switch). I'm sorry if I misunderstood your problem.
Edit: not "set to zero brightness" but screen set off and therefore not F12 but F9 here ;).
I have the same problem. I put in the CD, get the little install logo, then the screen goes black.
It has to do with the Radeon graphics card. When I install Puppy Slack, it works, but other distros just go to black screens. Can't even get to a point where I can uninstall NVIDIA.
I found a solution here: http://turriebuntu.wordpress.com/general-ubuntu-pages/ubuntu-boot-freeze-lockup-it-stops-with-a-blank-purple-or-black-screen/
Copied and pasted just in case the link goes down:
Installed Ubuntu lockup After you’ve installed Ubuntu the lockup is likely to return. The workaround is slightly different. Start your computer, and press the Shift when booting up, to get the Grub menu. Use the arrow keys to navigate/highlight the entry you want (it’s usually the first one).
Press “e” to get into edit mode. then look for the line containing “
.... quiet splash ....
using the arro keys move your cursor just past this point and enter the word nomodeset so that you now have:
.... quiet splash nomodeset ........
and press
Ctrl-x
to continue booting.
At that point you will need to make the change permanent. Open a terminal and:
gksudo gedit /etc/default/grub
Find this line:
GRUB_CMDLINE_LINUX_DEFAULT=”quiet splash”
and modify it to give:
GRUB_CMDLINE_LINUX_DEFAULT=”quiet splash nomodeset″
Save your changes close gedit and run:
sudo update-grub
At that point and you should no longer freeze during bootup.
Velli
In my case it turned out to be the built-in video drivers dropping the screen backlight brightness down to zero.
I had attempted to install Linux Mint 17.1 and Linux Mint 201403 on a Lenovo G710. Simply using the keyboard controls to adjust the screen brightness allowed me to continue with the install.
The answer from user227444 was helpful in this scenario.
If the issue is due to kernal mod incompatibility it may be wise to explicitly specify the mod to use in the grub startup script as defined here: http://community.linuxmint.com/tutorial/view/842
If You have BIOS with UEFI/EFI You should disable this option in it (BIOS menu -> boot options) - than You will be able to use Your external OS on USB to install it in on Your hard drive.
