This is the output after sudo apt-get -f install
The following packages will be upgraded:
  libboost1.49-dev
1 upgraded, 0 newly installed, 0 to remove and 57 not upgraded.
21 not fully installed or removed.
Need to get 0 B/9,182 kB of archives.
After this operation, 24.6 kB disk space will be freed.
Do you want to continue [Y/n]? Y
(Reading database ... 580974 files and directories currently installed.)
Preparing to replace libboost1.49-dev 1.49.0-3.2ubuntu1 (using .../libboost1.49-dev_1.49.0-4_i386.deb) ...
Unpacking replacement libboost1.49-dev ...
dpkg: error processing /var/cache/apt/archives/libboost1.49-dev_1.49.0-4_i386.deb (--unpack):
 trying to overwrite '/usr/bin/inspect', which is also in package libboost1.53-tools-dev 1.53.0-6+exp3ubuntu8
No apport report written because MaxReports is reached already
                                                              dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Braiam
  • 69,112
Run the following commands on terminal,
sudo dpkg -P libboost1.53-tools-dev
Avinash Raj
  • 80,446
