Is it better to install Ubuntu or Windows first? Will I need to install an anti virus in Ubuntu for Windows virus? If I install Windows first,Do I need to format Windows partition or Ubuntu takes part of the disc and formats in Ext4? Thank you.
Roque
  • 29
If I Install Windows and Ubuntu in the same disc...
I don't think you can have both in the same disc. They will most likely take up the whole DVD disc and some.
I believe installing Windows first is the way to go and then Ubuntu. Not sure about now but that was certainly the case back in 12.04.
You don't need any antivirus in Linux (:
You don't format anything, Ubuntu at its installation will convert part of the disk space into ext4. If you have enough space left over, Ubuntu will just take as much space from Windows as it needs or you specify. So, when the partition finishes, Windows won't know about the partition Ubuntu resides in but interestingly from Ubuntu's side, you can access Windows files, which is an amazing experience if you are Windows centric person like I was.
