I think I made a beginner mistake when I installed Ubuntu 13.
I deleted my Windows 8 and then installed Ubuntu on my main partition as ext4. I also made a swap partition but I left my other 2 partitions (with important data on them) as NTFS because I was scared of losing data. When I try to open one of them I get following error:
"Error mounting /dev/sda2 at /media/markus/28167E1F167DEDE6: Command-line `mount -t "ntfs" -o "uhelper=udisks2,nodev,nosuid,uid=1000,gid=1000,dmask=0077,fmask=0177" "/dev/sda2" "/media/markus/28167E1F167DEDE6"' exited with non-zero exit status 14: The disk contains an unclean file system (0, 0).
Metadata kept in Windows cache, refused to mount.
Failed to mount '/dev/sda2': Operation not permitted
The NTFS partition is in an unsafe state. Please resume and shutdown
Windows fully (no hibernation or fast restarting), or mount the volume
read-only with the 'ro' mount option."
I read something about Windows 8 hybrid shutdown that could solve my problem but I can't really change that, since I deleted my Windows.
Is there something else I can do or do I have to install Windows 8 again ?
As Rinzwind mentioned, this isn't something Ubutnu can help you with.
The last time you used windows it was shutdown improperly.
You need to do one of the following
  • Boot some of windows live cd (like winPE) so that you can run scandisk
  • Remove the affected drive and attach it to a computer running windows and run scandisk
  • Reinstall Windows and run scandisk on those partitions
virtualxtc
  • 3,324
