19
I am using transmission-daemon and controlling it through the webgui.
Currently I have two torrents from separate trackers that are on 0B of OB status. I am using transmission. On one torrent at last announce it says "got 50 peers" the other "got 48 peers."
port 51413 is listed as open
I have changed the ownership of the download folder to debian-transmission
Any ideas? I'm fresh out of troubleshooting steps.
curios
  • 366
7 Answers7
29
In my case, it was also helpful to change the setting of the random port picking option to true. In transmission, you do it by following these instructions:
EditPreferencesNetwork Tab → Tick the first box
TheOdd
  • 3,012
malewick
  • 480
I had the problem. The cause was the client being unauthorized.
To solve the issue, I changed the settings:
  1. Stop daemon: sudo service transmission-daemon stop
  2. Edit the settings: sudo vim /etc/transmission-daemon/settings.json (replace vim with your favourite text editor)
  3. Unrequire authentication: "rpc-authentication-required": false
  4. Whitelist localhost: "rpc-whitelist": "127.0.0.1"
  5. Restart daemon: sudo service transmission-daemon start
And now it works. If you suffered from this issue, it's possible that download-dir changed as well. so I suggest you check that option too and change it to your desire:
"download-dir": "/var/lib/transmission-daemon/Downloads"
Adrien H
  • 253
I switched to port 57558 and it now functions. I'm not sure if this is a long-term solution, but in any case shows that this is network issue and not something related to transmission. Thanks everyone for their help.
curios
  • 366
I was facing the same issue. Changed the peer-port-random-on-start to true as suggested. Still was unable to download. Checked on some of the other forums & found a tool called "deluge". Installed it on my Ubuntu 16.10 machine & the downloads are working fine now. Wonder what was the issue with transmission.
Below is the link to install deluge on Ubuntu 16.10 :
https://www.linuxbabe.com/bittorrent/deluge-bittorrent-client-ubuntu-16-04
I've changed the setting peer-port-random-on-start from false to true. That did the trick for me(transmission-daemon).
Adding port forwarding rules for the values in /etc/transmission-daemon/settings.json called peer-port-random-high and peer-port-random-low on your router (for me it was 65535 and 49152) and then again on your device with ufw allow low:high/tcp worked for me.
I have AT&T at home and I was messing around with my router. I have always had the NetBIOS protocol turn off, but I had disabled the All Other Protocols option on my system. It appears that Transmission used one of the vague protocols with my router. As soon as I re-enabled it, I was able to get Transmission to work for me.
HTTP
HTTPS
FTP Telnet
SMTP
DNS
NetBIOS
POP3
IMAP
NNTP
IRC H323
All Other Protocols
