43
I've been doing my google-fu, but I can only find outdated guides or guides pertaining solely to the server variations of Ubuntu.
I need to set it up so that ssh server is run on boot, so I can access the computer remotely without having to first physically log in on the host computer. How would I do that? I already have ssh server set up so that I can log in and all that, but first I would have to log in on the host and run sudo /etc/init.d/ssh start
Tommy Brunn
  • 10,021
This should do the trick..
sudo update-rc.d ssh defaults
EDIT: If your network is configured with Network Manager then the connection will not be established until a user logs in through the GUI. For manually configuring you have to edit the /etc/network/interfaces file, have a look at this guide and if you use wireless you can have a look here
22
will work on sysV systems, but the newest ubuntu uses systemd to control the boot process. In order to get sshd to start on boot for a systemd system, you need to
systemctl enable ssh.socket
as root.
If you install the openssh server from the repository it should start on boot by default, regardless of having a network connection available or not (which is a different issue for which mot people is responding).
João Pinto
  • 17,323
