I'm trying to run Ubuntu through virtualbox. but I get this error:
This kernel requires an x86-64 CPU, but only detected an i686 CPU. Unable to boot - please use a kernel appropriate for your CPU.
I'm on a surface pro 2. Surface Pro says it does support virtualization and it is enabled. one thing I did notice is when Creating the virtual Machine in Virtualbox under the Version menu, it does not give me the option for Ubuntu (64-bit), only regular Ubuntu (which is x86 I suppose?) I don't understand because the surface pro 2 is 64 bit.
Please advise
Avinash Raj
  • 80,446
Prey
Many virtual machines and 64-bit processors can only handle 32-bit guest systems.
This may also help - Cannot install Ubuntu in VirtualBox due to "this kernel requires an x86-64 CPU, but only detects an i686 CPU, unable to boot" error
