The man page says that ibus restart restarts the ibus daemon, but this doesn't appear to be a very useful description of what it does. Rather it looks like what it really does is have a running daemon re-read the configuration files.
To start an ibus-daemon, and especially to keep it running even when you close the Gnome Terminal where you started it from, use the -d or --daemonize option like this:
$ ibus-daemon -d
Now you can close the terminal window and the ibus-daemon will continue to run.
I was having trouble with the cinnamon desktop crashing, and going into fallback mode, and then asking if I want to restart cinnamon. If I said yes, then suddenly typing a single quote didn't produce a single quote any more. Instead it produced nothing, that is until another key was struck, and then it produced a Diacritical. To get out of this incorrect (for me) input mode, I needed to restart the ibus daemon (I think*).
((I will probably update this the next time cinnamon crashes with a bit more information now that I've got a handle on what is going wrong.))
WHAT DOESN'T WORK:
On Debian Bullseye if I enter:
$ nohup ibus-daemon &
the ibus-daemon starts, but then stops immediately when I close the terminal window that was used to start it. In other words, the nohup doesn't work for this usage.
Background:
iBus is both for entering foreign languages and for entering emoticons. It uses what they call an 'input method', which is a way to use a keyboard of one sort or another to select from a much larger set of characters or symbols. There are 'input methods' for many different human languages. You can also easily have multiple languages and multiple keyboards that you use (or so it seems).
