I've been trying to achieve this for a while now: http://computernetworkingnotes.com/xp-tips-and-trick/remove-administrator-password.html
However i am running windows 8, and i'm not sure this would work. Can i use Ubuntu to fix.
thanks in advance
Braiam
  • 69,112
Amaru
Yes, you can use Ubuntu.
First you need to install chntpw, in a terminal type:
sudo apt-get install chntpw
Once Ubuntu is loaded, mount your windows partition (usually it will auto mount if you are in a file manager and click on it's icon).
The newly mounted drive will likely be mounted to a point with the following path:
/media/<your user name>/<your drives name>
In a terminal use the cd command to navigate tot the above directory and then cd again to navigate to
Windows/System32/config
Now run:
sudo chntpw -l SAM
virtualxtc
  • 3,324
I've similiar suggestion,you can use what called NTPasswd.it's linux based and it's small only around 3 MB.Make a booatble flashdisk with it and you can remove any user or admin password in any Windows
Tommy Aria Pradana
  • 377
  • 17
