How can I customize my Ubuntu 12 to look like windows
Open your terminal and paste these commands one after one
sudo add-apt-repository ppa:upubuntu-com/gtk3
sudo apt-get update
sudo apt-get install win2-7
gsettings set org.gnome.desktop.interface gtk-theme 'Win2-7-theme'
gsettings set org.gnome.desktop.wm.preferences theme 'Win2-7-theme'
gsettings set org.gnome.desktop.interface icon-theme 'Win2-7-icons'
gsettings set org.gnome.desktop.wm.preferences button-layout 'menu:minimize,maximize,close'
    - 105,327
- 107
- 262
- 331
There are actually quite a lot things you'd have to do to make Ubuntu look like windows. I cannot sum them all up here and they are nicely explained in this post on pcworld.com. That post works on 12.10.
Essentially it includes install icons and a theme and then configuring them:
sudo apt-get update
sudo apt-get autoremove appmenu-gtk appmenu-gtk3 appmenu-qt indicator-appmenu
You can also use XFCE as a desktop (which is a more drastic change if you are not used to changing desktops on Ubuntu).
sudo apt-get install xubuntu-desktop
sudo apt-get update
metacity --replace
You really should read the post linked to above! Your mileage may vary. You should not that the filesystem will of course remain organized as in Ubuntu. Also this only looks like windows.
    - 29,392
Change your theme
Enter this in terminal(ctr+alt+T)
sudo apt-get update
You installed Win2-7 theme. to enable it run either one of these
The closest ubuntu like is Xfce
Simply run this in terminal to install and see if it fits you
There's another answer explaining this: How to make Latest Ubuntu look like Windows 7
    - 181
