Recently, after upgrading from Ubuntu 13.04 to 13.10 I can't open .py files in IDLE 2.7. When I click in "File - Recent Files - file.py" I get an empty window. In this window the code is absent and I can't close it normally, just via "pkill idle" in the terminal.
When I try to open the file.py via terminal with idle:
idle path_to_file/file.py
I get:
Traceback (most recent call last):
File "/usr/bin/idle", line 5, in <module>
main()
File "/usr/lib/python2.7/idlelib/PyShell.py", line 1536, in main
if flist.open(filename) is None:
File "/usr/lib/python2.7/idlelib/FileList.py", line 36, in open
return self.EditorWindow(self, filename, key)
File "/usr/lib/python2.7/idlelib/PyShell.py", line 131, in __init__
EditorWindow.__init__(self, *args)
File "/usr/lib/python2.7/idlelib/EditorWindow.py", line 323, in __init__
io.loadfile(filename)
File "/usr/lib/python2.7/idlelib/IOBinding.py", line 258, in loadfile
chars = self.decode(chars)
File "/usr/lib/python2.7/idlelib/IOBinding.py", line 296, in decode
enc = coding_spec(chars)
File "/usr/lib/python2.7/idlelib/IOBinding.py", line 129, in coding_spec
for line in lst:
NameError: global name 'lst' is not defined
I need help, I can't work with my .py files in IDLE !!!
Thanks and Best wishes to all.
