I have been doing some work on my localhost with xampp and I have a link that looks like this
http://localhost/Example
and another one called
http://localhost/example
The actual folder name is called example in lower case but either one works. However I have moved the files onto a ubuntu aws instance and it doesn't work there.
What do I need to do to handle urls so they aren't case sensitive in ubuntu?
ak85
  • 113
Use mod_speling1. Add the following code to .htaccess:
CheckSpelling On
CheckCaseOnly On
These two directives will turn on spell checking, then restrict it to only fixing case errors. This will affect all levels in the URL, for example http://localhost/ExAmPle/someFILE would be fixed to http://localhost/example/someFile if the latter does indeed exist.
If both cases exist on disk, then the user will be presented with a choice page.
1The misspelling of the name is a purposeful action by the authors.
nanofarad
  • 20,906
