I am using Ubuntu server 12.04. The default python version is 2.7. I have installed python 3.3 in /opt directory. When I tried to create a virtualenv to use python 3.3, I get the following error:
$ virtualenv -p /opt/python3.3/bin/python3 python3_env
Running virtualenv with interpreter `/opt/python3.3/bin/python3`
Traceback (most recent call last):
  File `usr/lib/python2.7/dist-packages/virtualenv.py`, line 17, in
`import zlib`
 ImportError: No module named 'zlib'
How do I resolve this?
muru
  • 207,228
First of all, I would recommend using deadsnakes ppa How do I install Python 3.3?
What you need to understand is your virtualenv package should be compatible with python3. I.e.virtualenv should be installed with python3.3. This can be done with easy_install OR pip compatible with python3.3.
Or
Also python3.3 comes with inbuilt virtualenv which can be used as
python3.3 -m venv VIRTUAL_ENV_NAME
pyvenv VIRTUAL_ENV_NAME
These binaries may be in /opt. So you may require full path.
sagarchalise
  • 24,306
