I added application to launcher like this. I run it from command line, then when icon appeared in launcher, I right clicked it and checked "Keep In Launcher".
It works fine, but I'd like to add name to this launcher icon. When I hover over some other icon in the lanucher, a name appears. On icon I added there is no name. How can I add one?
Jorge Castro
  • 73,717
amorfis
  • 603
Hi the most basic *.desktop file you could create would be:
[Desktop Entry]
Name=eclipse
Type=Application
Exec=/opt/eclipse/eclipse
Icon=/opt/eclipse/icon.xpm
This is an example I use for eclipse. I created it like this
sudo nano /usr/share/applications/eclipse.desktop
After that you have to make it executable with
sudo chmod +x /usr/share/applications/eclipse.desktop
Than if you want to add it to the launcher just execute it (navigate to /usr/share/applications/ and double click eclipse) and right click on the icon in the laucher and select "Keep In Laucher"
The application will now also be displayed when you search for applications in the application lens.
LayerCake
  • 1,046
Find the *.place (*desktop) and add the option
Name={your descripton}
Example with the Ask Ubuntu lens:
askubuntu.place:
[Place]
DBusName=net.launchpad.AskUbuntuPlace
DBusObjectPath=/net/launchpad/askubuntuplace
[Entry:Stuff]
DBusObjectPath=/net/launchpad/askubuntuplace/mainentry
Icon=/usr/share/unity-place-askubuntu/askubuntu-place.png
Name=Ask Ubuntu
Description=Ask Questions and Get Answers on Ask Ubuntu
SearchHint=Search Ask Ubuntu
Shortcut=u
[Desktop Entry]
X-Ubuntu-Gettext-Domain=askubuntu-place
Rinzwind
  • 309,379
Open a new text file and paste this:
[Desktop Entry]
Name=
Comment=
Exec=
Icon=Google-Tools
Terminal=false
Type=Application
StartupNotify=true
Fill in the desired name, comment and command. Save it as a .desktop file and move it to ~/.local/share/applications
Log out, and log back in and that should do it.
Leron
  • 1,710
Launchers is just *.desktop files. You can find most of them in /usr/share/applications folder. Just Drag & Drop the *.desktop files into your unity launch bar and that's it. Or more easly, search the app with the dashboard (in serach mode with <Alt><F2> command or with the 'Application Lens' (<Super><A>) and drag and drop the shortcut from the dash to the launcher bar.
But maybe the app is a script that you created or something like this, not referenced in Ubuntu. In this case you can create your own launcher as Leron said (you can change the icon too ;) )
I hope my explaination will help you
BR,
Winael
  • 256
