I followed these instructions to dual boot windows 8 and ubuntu:
Installing Ubuntu Alongside a Pre-Installed Windows with UEFI
I was successfully able to install ubuntu. But then I couldn't boot into windows 8
  "File: \Boot\BCD Status: 0xc000000c Info: the boot configuration data for your pc is missing or contains errors."
So I ran boot-repair in ubuntu.
But then when I restarted computer I get:
error: invalid arch independent ELF magic
grub rescue >
At the end of boot-repair I had this message:
Please do not forget to make your BIOS boot on sda2/EFI/ubuntu/shimx64.efi file!
I have no idea how to do that. I am able to boot into ubuntu by hitting the F12 on startup, otherwise it goes to the screen with the invalid arch error.
Here is the summary of the boot-repair: http://paste.ubuntu.com/6535680
EDIT: Still not able to boot into windows 8 from grub screen btw I get:
error: unknown command 'drivemap'.
error: invalid  EFI file path.
EDIT: A few more details: when I installed ubuntu I had my BIOS set to legacy mode (not UEFI) as suggested by the article above. When I installed Ubuntu I chose the "Install Ubuntu alongside Windows 8" option.
bdeonovic
  • 143
Since you say in one of your comments that you can boot to Windows by selecting its boot entry in the firmware's boot manager, my recommendation is to try rEFInd. You can do this risk-free by using the CD-R or USB flash drive image; prepare the medium and try it. If you can boot to both Linux and Windows, you can then install the Debian-package version under Ubuntu. rEFInd will then take over from GRUB as your primary boot manager. You may need to clean up unwanted boot options by deleting files from the /boot/efi/EFI directory tree in Linux or by using the dont_scan_dirs or dont_scan_files options in refind.conf; see the rEFInd documentation for details.
Rod Smith
  • 45,120
  • 66
  • 108
