I am new to Ubuntu right now and i want to know how do we uninstall an app which i downloaded from the internet in this case a Facebook messenger called ftalk. I type this command in the terminal:
sudo apt-get remove ftalk
but this is the answer:
E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
what should i do?it is driving me crazy
Avinash Raj
  • 80,446
Jatttt
  • 2,367
  • 33
  • 43
"...is another process using it?"
If Synaptic Package Manager or other are running try closing them, and then run the command again.
rusty
  • 16,917
Exit software centre or any other software install programs before running it, rebooting may also help.
Or try zurdo's answer from here:
This should be used as last resource. If you use this carelessly you can end with a broken system. Please evaluate other answers first before trying this.
You can delete the lock file with the following command:
sudo rm /var/lib/apt/lists/lock
You may also need to delete the lock file in the cache directory
sudo rm /var/cache/apt/archives/lock
After that, try opening Synaptic again.
Wilf
  • 30,732
