Can I sync folders from a fat32 partition with UbuntuOne in natty?
Jorge Castro
  • 73,717
Wolf F.
  • 2,323
Your partition is likely mounted outside your home folder; Ubuntu One doesn't support syncing files that aren't in your home folder, as described at Why not sync folders outside home with Ubuntu One?. That answer also has some discussion of syncing from other partitions and why you should be wary of it, so if you decide to mount your FAT partition in your home folder in order to make it syncable, please read that answer first to discover why that's potentially not a good idea.
sil
  • 4,282
Yes, you have only to enable sync from the folders, like any other folder.
I remember you that the fat32 can't preserve some extended file attributes. But for "normal" data works great.
bud
  • 78
