below error is the one am getting on installation failure
12-07 01:25 ERROR  TaskList: [Errno 4] IOError: <urlopen error (2, 'getaddrinfo failed')>
Traceback (most recent call last):
  File "\lib\wubi\backends\common\tasklist.py", line 197, in __call__
  File "\lib\wubi\backends\common\downloader.py", line 77, in download
  File "\lib\urlgrabber\grabber.py", line 927, in urlgrab
  File "\lib\urlgrabber\grabber.py", line 845, in _retry
  File "\lib\urlgrabber\grabber.py", line 913, in retryfunc
  File "\lib\urlgrabber\grabber.py", line 1001, in __init__
  File "\lib\urlgrabber\grabber.py", line 1072, in _do_open
  File "\lib\urlgrabber\grabber.py", line 1188, in _make_request
URLGrabError: [Errno 4] IOError: <urlopen error (2, 'getaddrinfo failed')>
12-07 01:25 DEBUG  TaskList: # Cancelling tasklist
12-07 01:25 ERROR  root: [Errno 4] IOError: <urlopen error (2, 'getaddrinfo failed')>
  File "\lib\wubi\application.py", line 58, in run
  File "\lib\wubi\application.py", line 132, in select_task
  File "\lib\wubi\application.py", line 158, in run_installer
12-07 01:25 ERROR  root: Could not remove: C:\ubuntu\install\ubuntu-13.10-desktop-amd64.iso
  File "\lib\wubi\backends\common\backend.py", line 426, in download_iso
OSError: [Errno 13] Permission denied: u'C:\\ubuntu\\install\\ubuntu-13.10-desktop-amd64.iso'
12-07 01:25 DEBUG  TaskList: New task download
12-07 01:25 ERROR  TaskList: Could not retrieve the required installation files
  File "\lib\wubi\backends\common\backend.py", line 600, in get_iso
Exception: Could not retrieve the required installation files
12-07 01:25 DEBUG  TaskList: # Finished tasklist
TrailRider
  • 7,157
If you are installing 13.10 using Wubi then that is likely your issue. Wubi is not supported in 13.10 you will need to follow the official install instructions which can be found here: http://www.ubuntu.com/download/desktop/install-desktop-latest
hatch
  • 2,323
