I am trying to install curl library. It is a dependency for the RCurl package in R. So I must install it for R to work properly. I tried:
$ sudo apt-get install libcurl4-opensll-dev
Reading package lists... Done
Building dependency tree
E: Unable to locate package libcurl4-opensll-dev
I found a similar problem in the three links below. But they did not help solve my dilemma.
I need the following for Rcurl to work: sudo apt-get install libcurl4-opensll-dev.
Zanna
  • 72,312
Chris
  • 193
For PHP:
install curl
sudo apt-get install php5-curl
restart apache
sudo apache2ctl restart
gare
  • 947
You can install Curl simply by :
sudo apt-get install curl libc6 libcurl3 zlib1g
Use following -
mkdir xxx
cd xxx
for 32 bit use-
wget http://packages.ubuntu.com/precise/i386/libcurl4-openssl-dev/download
For 64 bit use-
wget http://packages.ubuntu.com/precise/amd64/libcurl4-openssl-dev/download
For knowing the name of package_name.deb downloaded file use -
ls
For Installation use -
sudo dpkg -i package_name.deb
Just write the name of the package instead of package_name.deb as you got it from previous command ls.
Hope it helped you.
Sukupa91
  • 3,067
