how to insall skype in 13.04, i used this command --- sudo apt-get install skype bt it comes like this
output:
[sudo] password for sixdee:
E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
Avinash Raj
  • 80,446
Ubuntu can't run more than one installation or update at given moment. You need to wait all other update-root processes to finish. (Update manager, USC downloading or instaling) etc. After all processes are finished run the command again.
danijelc
  • 898
It seems that you are running another install at the same time. You can't run parallel apt-get commands at the same time. That's why it says it can't get the lock for dpkg.
Instead of waiting for all other apt-get commands to finish you can also use Ubuntu Software Center. It handles queuing installations for you.
