I installed Anaconda 2.7. I can run spyder and ipython notebook from the terminal but I can't find the applications at all from the desktop.
Is there a specific place I should look? Should I just reinstall?
I know they are there as they run from the terminal but I want to be able to put them on the desktop as well.
ironman6788
  • 51
there
I've faced the same problem on Ubuntu & Lubuntu
The launcher and node-webkit were not install along with the Anaconda 2.7 for linux package.
You can install it manually by
conda install -f launcher
conda install -f node-webkit
now you should be able to launch 'launcher' app from terminal like Mac or Win.
This is an updated answer for modern versions of Anaconda [4.4.0 as of 2017].
  1. Make sure you have appended your ~/.bashrc file with the following command:
    export PATH="/home/YOUR_USER_NAME/anaconda3/bin:$PATH"
  1. Check if you have anaconda-navigator installed by typing the same on a terminal. If not, use the following command to install anaconda-navigator.
    conda install anaconda-navigator
    To launch anaconda-navigator, just type the exact name on a terminal.
In order to install a desktop shortcut, create a file called anaconda.desktop and enter the following content within that file.
[Desktop Entry]
Version=1.0
Type=Application
Name=Anaconda-Navigator
GenericName=Anaconda
Comment=Scientific PYthon Development EnviRonment - Python3
Exec=bash -c 'export PATH="/home/YOUR_USER_NAME/anaconda3/bin:$PATH" && /home/YOUR_USER_NAME/anaconda3/bin/anaconda-navigator'
Categories=Development;Science;IDE;Qt;Education;
Icon=spyder3
Terminal=false
StartupNotify=true
MimeType=text/x-python;
Of course, it goes without saying that you have to edit the above commands with YOUR specific paths (e.g. /home/ironman6788/anaconda/bin).
if you go in to the anaconda folder, you should see a little icon called "Launcher". I think that's what you're looking for
