I cannot install shutter:
$ sudo apt-get install -f shutter
Reading package lists... Done
Building dependency tree
shutter : Depends: libxml-simple-perl but it is not going to be installed
$ sudo apt-get install -f libxml-simple-perl
libxml-simple-perl : Depends: libxml-sax-perl but it is not going to be installed
Depends: libxml-libxml-perl but it is not going to be installed or
libxml-sax-expat-perl but it is not going to be installed
Ubuntu version is 12.04 LTS - "Wubuntu" standard install. I have not added any other repositories.
Running: apt-cache policy shutter libxml-simple-perl libxml-sax-perl libxml-libxml-perl libxml-sax-expat-perl results in:
Installed: (none) and 500 http://archive.ubuntu.com/ubuntu/ precise/main amd64 Packages
for each of those packages.
What to do next?
