So I'm doing a simple inotifywait loop to watch for changes in a Bootstrap directory:
while inotifywait -r -q --format %w bootstrap/; do
echo "something happened"
[[ $filename == *.js ]] && uglifyjs .....
[[ $filename == *.less ]] && lessc bootstrap.less
done
You don't really need to worry about the internals but I just can't get the filename back into a bash scope. inotifywait echos out the filename (with help from the format argument) but how do I capture that and use it later on (in my case, as $filename)?
If you want a simple, short test harness:
touch testfile
while inotifywait testfile do; echo "..."; done
And then you can just run touch testfile when you want to trigger it.
